http://cycle.shimano... ... call_.html
Shimano announces voluntary recall of PRO, SHIMANO and SAINT cycling gloves
It has recently come to Shimano's attention that, contrary to its strict contractual specifications, certain PRO, SHIMANO and SAINT cycling gloves manufactured by Shimano's supplier in Pakistan contain traces of Benzidine in excess of the levels specified by EU regulations.
As a precaution, Shimano has voluntarily decided to recall all PRO, SHIMANO and SAINT cycling gloves which carry a label indicating that they were made in Pakistan, or which carry no label at all. Cycling gloves that carry a label indicating they were manufactured elsewhere are not affected by this recall. The label is located on the inside of the gloves.
If you have a pair of gloves affected by this recall, or if you are unsure, you should stop using the gloves immediately, and should either visit a Shimano- / Pro-dealer and/or read the PDF version of the information for your country as listed below: (ima i nas)
Shimano povlaci seriju rukavica
, Dec 12 2007 06:34 PM
6 odgovora na ovu temu
Postavljeno 12 December 2007 - 06:34 PM
Postavljeno 12 December 2007 - 07:00 PM
Ma, čisto kad neko naš svrati do neke podrum-radnjice uvozne opreme da prčka po rukavicama, nek' obrati pažnju...
Postavljeno 12 December 2007 - 07:26 PM
Posle kažu nema razlike da li je rađeno na istoku ili ne i ja treba da im verujem. Navodno je ista tehnologija...jeste đoku moj ista.
A skoro je otvorena tema o pedalama i tome kako se za UK tržište tamo i proizvode. Ali ti ljudi nisu sisali vesla i neće da uvoze šljam. I čisto sumnjam da uzorka ovih rukavica i ima po zapadnoj evropi.
Postavljeno 12 December 2007 - 08:43 PM
Ljudi, kada bi pogledali ko je i zasta sve radio SAFETY RECALL...pa to bi bila lista duga metrima i metrima...ne samo u biciklizmu, vec i u ostalim segmentima zivota, najpoznatiji slucaj sa MATELL lutkama za decu...a od brandova u biciklizmu, SVI su imali gafove, i Cannondale, Giant, Rockshox, manitou, shimano, Sram....da ne nabrajam...ali se sada postavlja drugo pitanje: DA LI JE ZVANICAN DISTRIBUTER OVDE I ZAKONSKI OBAVEZAN DA SVAKU OVAKVU REKLAMACIJU JAVNO OBJAVI, OBEZBEDI DRUGE DELOVE ZA ZAMENU ISL...ovde se to nikada nije dogodilo. Zbog toga sto radim u firmi koja radi sa medic.i labor. materijalom znam da smo mi kao uvoznici reagenasa i sl. medic. sredstava U ZAKONSKOJ OBAVEZI ne samo da u najkracem roku obavestimo Agenciju za lekove, vec i da povucemo momentalno sa trzista eventualna sporna sredstva, stavimo ih u karantin i damo na unistenje...Dakle, zakon postoji, samo da li se sprovodi...Pitanje je takodje sta bi se desilo da se takav proizvod donese u radnju gde je i kupljen. Recimo bas te rukavice
Postavljeno 12 December 2007 - 09:10 PM
Dva scenarija mi padaju na pamet:
1 - Uđeš u radnju, pružiš im fiskalni i kažeš 'Evo, doneo sam vam ove rukavice, Šimano je rekao da ih vratimo u radnju jer su otrovne.' Prodavac ti klimne glavom, popunite onaj obrazac za storniranje, ti dobiješ pare nazad, prodavac se namiri sa Šimanom na predviđen način.
2 - Uđeš u radnju... i prodavac se napravi blesav. Zahvališ se i odeš kući. Zovneš inspekciju i ukažeš im na opoziv i reakciju u radnji, a onda mejlneš Šimano.
Ili im (u radnji) predočiš šta će da se desi kad odeš kući. Onda prelazite na stavku 1. ili ideš kući
Svi ostali slučajevi koji funkcionišu po sistemu 'garancija do vrata' i 'ne znam ja ko si ti' ne podležu ovom.
