Cannondale
Postavljeno 11 June 2011 - 06:57 PM
Cannondale 2011 RZ One Twenty 4 Full Suspension Mountain Bike - Medium, 26", White
cena 1300USD
PS: cifra do koje dolazi u obzir za bicikl je do 1300USD.Molim i za druge predloge ako sam omanuo.
Pozdrav svima i hvala unapred.
Postavljeno 11 June 2011 - 07:42 PM
Postavljeno 11 June 2011 - 07:43 PM
Frame: RZ One Twenty, 120mm, SmartFormed Alloy, BB30, 1.5 Si headtube
Fork: RST Deuce Air, 120mm, lockout, rebound, 15mm thru axle, 1.5"
Crank: Shimano M430-8, 44/32/22
Chain: KMC X9 (SLV/GRY) 109L
Rims: Maddux, 32 hole
Spokes: DT Champion 1.8 Black
Tires: Kenda Slant 6 2.1" Wire bead
Pedals: FPD ALLOY, PLATFORM, BLK
Bottom Bracket: Shimano ES-25 Octalink
Rear Cogs: SRAM PG950 11-34T
Front Derailleur: Shimano Alivio 34.9mm clamp Bottom Swing
Rear Derailleur: Shimano Deore
Shifters: Shimano Deore
Handlebars: Cannondale C3 riser, 680 x 20 mm, 6061 alloy
Stem: Cannondale C3 1.5 +5 S(90), M-L(100), X(110)
Headset: Tange Seiki 1.5" Semi-integrated
Brakes: Shimano M445
Seat Post: Cannondale C4, 31.6 x 400
Wheel Rims: Maddux, 32 hole
Rear Shock: X-Fusion 02 RL2
Saddle: Cannondale Stage 2
Grips: Cannondale alloy locking grips w/closed end
Postavljeno 11 June 2011 - 07:56 PM
Postavljeno 11 June 2011 - 08:09 PM
* veličina točka: 26"
* veličina rama: L
* broj brzina: 27
* ram: Trail SL Save / aluminijum 6061
* viljuška: RockShox Recon silver TK solo Air 100mm
* menjač zadnji: Shimano XT
* menjač prednji: Shimano Deore
* ručice menjača: Shimano SLX
* ručice kočnica: Hayes Stroker Ride Comp
* kočnice: Hayes Stroker Ride Comp 160mm
* pogon: Shimano Deore, 44/32/22
* volan: Cannondale C3 riser
* lula: Cannondale C4
* sedište: Cannondale C4
* nabla prednja: Shimano M525
* nabla zadnja: Shimano M526
* lanac: Shimano HG53
* zadnji zupčank: Shimano HG50
* felne: Maddux DC3.0
* gume: Schwalbe Black Jack 26x2.1
Postavljeno 11 June 2011 - 09:06 PM
Hvala svima jos jednom.
Postavljeno 11 June 2011 - 09:23 PM
Postavljeno 11 June 2011 - 10:25 PM
* veličina rama: M
* težina: 13.50 kg
* broj brzina: 27
* ram: aluminijum 6061
* prednja viljuška: Rock Shox Tora / Lockout / hod 120 mm
* zadnji amortizer: Manitou Radium RL Air Lockout / hod 110 mm
* šolje volana: Ritchey OE 1 1/8" poluintegrisane
* menjač zadnji: Shimano SLX RD-M660
* menjač prednji: Shimano Deore FC-M531
* ručice menjača: Shimano Deore SL-M530
* ručice kočnica: Shimano BL-M486 / Disc
* kočnice: Shimano BR-M486 / Disc, Rotori 180/F, 160/R mm
* pogon: Shimano FC-M442 / 44x32x22
* volan: Scott Pilot 18 Pro / OS / 640mm
* lula: Scott Comp / OS / 6° ugao
* pedale: Wellgo LU-998-S
* šticna: Scott Comp / 31.6mm
* sedište: Scott Racing
* nabla prednja: Scott Comp Disc
* nabla zadnja: Shimano FH-RM65 Disc
* lanac: Shimano CN-HG53
* zadnji zupčank: Shimano CS-HG80 11-32
* felne: Alex XC-44 Disc 32H
* gume: Continental Mountian King 26 x 2.2
Postavljeno 12 June 2011 - 07:47 AM
primer:
ovakav bike je prodat prosli put na aukciji za 1700$
http://cgi.ebay.com/... ... 500wt_1156
Postavljeno 12 June 2011 - 10:56 AM
Imas ovde na oglasu FS Cannondale Scalpel i nije puno skup.
http://www.cikloberz...ow.php?id=40439
Postavljeno 13 June 2011 - 08:24 PM
Svima treba FS bajs. Samo ima onih koji to ne mogu da priuste (ili im trosenje para na bicikl nije najvisi prioritet) i onih koji mogu. Neki od onih koji ne mogu ili (ne znam zasto) nece, ubedjuju i sebe i druge da im to ni ne treba. Ako XC i XCM prvaci sveta voze FS, onda je samo pitanje para da li kupiti FS, a ne da li je to potrebno.Ali po onome sto si naveo tebi ne treba FS ram.
Sto se komentara "To je AM bajs" tice, opet ne znam odakle to iskopase, 120mm je sasvim XC danas.
Novi "upotrebljivi" FS biciklovi pocinju od 1000-1200$. Upotrebljivi HT biciklovi pocinju vec sa oko 300$...
Postavljeno 13 June 2011 - 08:47 PM
Postavljeno 13 June 2011 - 09:28 PM
Postavljeno 17 June 2011 - 07:51 AM
Posto Kristofer nije takmicar, tim pre mu treba FS, jer mu nesto malo dodatne tezine jos manje znace nego takmicarima.
Koliko sam shvatio, mozes da priustis 1300$. Zasto bi za te pare kupio neudobni Ferrari, ako mozes da se vozis u udobnoj limuzini?
Jedina moguca objasnjenje koja meni padaju na pamet su nemanje para, mazohizam ili neiskustvo.
Ja sam (na zalost) 5 godina vozio HT. Od kada sam "otkrio" FS, nisam prezalio tih 5 godina protracenih u mucenju sopstvenog tela. Jedino sto tih pet godina nisam bio ni svestan da to moze da izgleda i oseca drugacuje...
Sto se cena u USA tice, uskoro ce krenuti modeli za 2012 godinu, a tek tada pocinju pravi popusti na modele iz 2011-te. Tada ima realnih sansi naci masinu koja je bila $2000+ za tih 1200-1300$ koje si planirao da das...
Postavljeno 17 June 2011 - 01:38 PM
http://www.cikloberz...ow.php?id=40266
C/p opisa sa Ciklonauta:
MTB CANNONDALE f 800
- vel. 19.5, L
- vila Fatty Ultra sa lo
- menjači Shimano xt 772
- šalteri Shimano xt 770
- pogon Shimano XT 770
- lanac i kaseta Shimano hg93 i xt 770 11 x32
- kočnice XT 775, rotori 203mm 180mm
- točkovi Shimano wh m565 24 h, gume Schwalbe Black Jack 26x2,0
- pedale Shimano xt 770
- sedište San Marco Flex point white
- oprema Truvativ
Postavljeno 17 June 2011 - 01:45 PM
Lično bih više voleo za te pare nekog sa Lefty-jem umesto sa tom Fatty viljuškom.
Sad ne znam koliko je to realno za 850e...
