Pomoć oko kupovine polovnog bicikla
10 odgovora na ovu temu
#1 k_bozon
k_bozon
  • 7 posts
Postavljeno 29 September 2010 - 02:41 PM
Planiram da kupim avalanche gt 2.0 disc za 250e. Biciklo skoro da nije voženo, a staro je oko 2 godine. Možete li mi ukratko reći nešto o kvalitetu i opremi ovog bicikla? Inače, planiram da ga vozim po gradu i po malo off-road
#2 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 29 September 2010 - 02:45 PM
DAJ SLIKE ILI SPISAK OPREME.
puno znoja,malo krvi
#3 k_bozon
k_bozon
  • 7 posts
Postavljeno 29 September 2010 - 02:52 PM
Nemam slike, a ne znam ni spisak opreme. Evo spiska opreme sa GT sajta:
Brake Levers Tektro
Rear Brake Tektro Aquila cable actuated disc brake
Grips GT Lockdown dual density with allen key fixing bolts
Handlebar GT Mtn Riser, 15 mm rise, 6061 heat treated, 31.8 mm clamp
Headset Tange Seiki system for 1 1/8"
Pedals ATB Aluminum body, Steel cage, toe clip compatible
Seat Clamp GT Forged Alum QR
Seat Post Alloy Micro adjust 31.6 mm
Stem GT ATB, threadless 25 degree rise with four bolt alum CNC face plate for 31.8mm
Saddle WTB Pure V, with stitched cover and protective corners
Bottom Bracket Shimano Cartridge Sealed
Chain HG 40 Shimano 8 speed Chain
Crankset Chainwheel Shimano FC-M311 42/32/22
Front Derailleur Shimano M -330
Rear Derailleur Shimano Deore Shadow
Shifters Shimano 8 speed rapidfire shifters
Fork Suntour XCR-LO hydraulic fork with cr-mo 30 mm stanchions, magnesium lowers, preload adjust, 100 mm of travel and lock out
Frame GT NEW Triple Triangle design 6061 butted aluminum with Hydro formed top and downtube, zero stack headtube. Disc compatible with removeable der. Hanger
Sizes XXL,XL,L,M,S,XS
Front Hub Alloy QR for Disc
Nipples Brass CP
Rear Hub Aluminum QR sealed mechanism 8 speed cassette for Disc
Rims Jalco AX-430 Alloy double wall ATB
Spokes Stainless steel 14 gauge
Tires Kenda Nevegal, 26 x 2.1
Ovo je vjerovatno za najnoviju verziju bicikla, a ova sto ja planiram da kupim je iz 2008
#4 k_bozon
k_bozon
  • 7 posts
Postavljeno 29 September 2010 - 02:57 PM
Evo spiska opreme verzije za 2008 godinu:
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material GT 6061 Aluminum
Fork Brand & Model Suntour XCR-LO, 100mm travel
Fork Material Magnesium/cr-mo, single crown
Rear Shock Not applicable
Components
Component Group Mountain Mix
Brakeset Tektro Aquila mechanical disc brakes, Alloy linear levers
Shift Levers Shimano Alivio
Rear Derailleur Shimano M-531
Crankset Shimano M341, 22/32/42 teeth
Pedals ATB Resin body, Steel cage, toe clip compatible
Bottom Bracket Shimano Octalink
BB Shell Width Unspecified
Rear Cogs 8-speed, 11 - 32 teeth
Chain Shimano IG-31
Seatpost Alloy Micro Adjust
Saddle WTB Speed V
Handlebar Alloy Riser
Handlebar Extensions Not included
Handlebar Stem GT ATB
Headset 1 1/8" Tange Seiki
Wheels
Hubs Front: Alloy QR Disc, Rear: Shimano Disc QR
Rims Alloy Double Wall
Tires 26 x 2.10" Kenda Nevagal
Spoke Brand Stainless steel, 14ga. (2.0mm)
Spoke Nipples Brass CP
#5 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 29 September 2010 - 02:58 PM
Na ovom spisku imas shimanovu opremu za 2010 godinu znaci to nije to sto ces ti kupiti 2 godine staro.
#6 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 29 September 2010 - 03:00 PM
pa meni malo puno 250 za to.Mozes da kupis devetofaz sa full deore opremom u dobrom stanju za te pare.
#7 k_bozon
k_bozon
  • 7 posts
Postavljeno 29 September 2010 - 03:11 PM
On je sa tim biciklom prešao oko 150 km, a kupovao je i dodatke tipa: svjetlo, pumpu, velo8, rogove. Misliš da mogu naći bolju varijantu za te pare?
#8 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 29 September 2010 - 03:12 PM
http://www.cikloberz...ow.php?id=24336 meni je ovaj ok.Malo je kurbla izgrebana ali ima ok opremu za te pare.
#9 k_bozon
k_bozon
  • 7 posts
Postavljeno 29 September 2010 - 03:19 PM
Jeste bolja opcija, ali ja ću plaćati ovom drugu u 3 rate, a to mi je najveća povoljnost jer nemam toliko para da dam odjednom. Inače šta misliš o ovom biciklu koje planiram da kupim?
#10 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 29 September 2010 - 09:32 PM
Nemam nista protiv i nebih se bunio da ga posedujem,a i ako je tako malo presao odlicno.Ali obavezno uradi servis svih delova gde ima lezajeva,zameni sajle i buzire i ima da bude bombona.
#11 k_bozon
k_bozon
  • 7 posts
Postavljeno 30 September 2010 - 01:27 PM
OK, hvala ti
