Trenutno sam preumoran da bi prevodio, ali se vidi o čemu je reč:
Consumers urged to check connector link manufacture date
Component manufacturer SRAM has issued a voluntary recall on a limited number of 10-speed PowerLock chains due to PowerLock connector link failures it has discovered through its quality control process.
SRAM US Road PR and Media Manager Michael Zellmann released details of the action, stressing that the recall wasn't applicable to all SRAM chains, rather a limited number of PowerLock chains manufacturered between January and June 2009.
Those with concerns about their SRAM chain should examine the PowerLink connector outer plate to determine its date of manufacture. Those PowerLock connector links marked with an 'M' or 'N' may develop a crack during installation and/or use, and fail.
SRAM is retrieving and replacing all affected PowerLocks, which should be returned to SRAM bicycle dealers directly for replacement. The company advises those with affected chains to stop using the product immediately and return their chains to any SRAM dealer for verification of the product date stamp and to obtain a free replacement PowerLock.
http://www.cyclingne... ... ary-recall
SRAM issues PowerLock voluntary recall
gamzzy
, Aug 17 2009 10:52 AM
3 odgovora na ovu temu
Postavljeno 17 August 2009 - 11:23 AM
PowerLock lanci za desetobrzince proizvedeni od januara do juna ove godine koji imaju powerlink iz serije M ili N (piše na powerlinku) se povlače jer powerlink zbog greške u proizvodnji blagoizvoljeva da naprsne i pukne tokom upotrebe.
Postavljeno 17 August 2009 - 11:52 AM
Kako je ovo los pocetak za novu seriju. Mada, progledace im se kroz prste (valjda), s obzirom da je "samo" lanac u pitanju.
Postavljeno 17 August 2009 - 01:36 PM
Samo spojka, ne ceo lanac...Kako je ovo los pocetak za novu seriju. Mada, progledace im se kroz prste (valjda), s obzirom da je "samo" lanac u pitanju.
