Pomoć pri kupovini bajka :)
132 odgovora na ovu temu
#1 r1m1
r1m1
  • 5 posts
Postavljeno 16 July 2010 - 10:53 PM
Dobar večer!
Pošto sam mogu reći i početnik u biciklizmu, a isto tako početnik na ovom forumu tj. novajlija želio bih pitati nekoliko stvari:
1. Koji je bajk najbolji za 300e od ova 2., imam 80kg, 188 cm
1. GT Outpost 2010
(258.97 EUR)
2. Specialized Hardrock 2010
(298.46 EUR)
Ako još nešto možete dodatno preporučiti s ovog sajta:
http://www.ciklocentar.com/?jezik=bos
Hvala puno!
#2 r1m1
r1m1
  • 5 posts
Postavljeno 16 July 2010 - 10:54 PM
+ Da li je bolje ovo ili neki polar ili capriolo?
#3 mixitron
Postavljeno 16 July 2010 - 11:01 PM
Po opremi sa fotografije, 2.
#4 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 17 July 2010 - 06:30 AM
2. definitivno
puno znoja,malo krvi
#5 r1m1
r1m1
  • 5 posts
Postavljeno 17 July 2010 - 10:42 AM
GT Outpost 2010
Braking
Brake Caliper Front Radius linear pull brake
Brake Caliper Rear Radius linear pull brake
Brake Levers Shimano ST-EF50
Drive
Bottom Bracket Tange Cartridge Sealed
Cassette (Rear Cogs) Shimano Eight Speed Cassette, 11-32 ratio
Chain 8 speed index
Crank Suntour XCC-T02, 42,32,22
Pedals High Impact nylon platform
Gearing
Derailleur Front Shimano C-050
Derailleur Rear Shimano Acera
Gears 24
Shifter(s) Shimano ST-EF50 8 speed EZ fire shifters
General
Grips GT Dual Density ATB
Handlebar 20 mm Rise, 6 degree bend, anatomically sized
Headset Aheadset Threadless
Saddle GT Custom MTN with anatomic pressure relief
Seat Post Alloy Micro adjust
Seat Release / Collar Alum QR
Stem GT ATB, threadless 25 degree rise with four bolt alum face plate
Suspension
Fork Travel 75 mm
Forks SR M 3000, alloy crown, alloy lowers with 75 mm travel
Wheels
Hub Front Alloy QR
Hub Rear Alloy 8 speed Cassette with QR
Nipples Brass CP
Rims Alex ASD-1, double wall, black with silver side wall
Spokes Stainless steel 14 gauge
Tyres (Front & Back) ATB Dual purpose, 27 TPI 26 x 2.1
Wheel Size 26"
Specialized hardrock 2010
Braking
Brake Caliper Front V brake, alloy linear pull, 1pc. pad
Brake Caliper Rear V brake, alloy linear pull, 1pc. pad
Brake Levers Alloy, linear pull
Drive
Bottom Bracket Sealed cartridge, square taper, 68mm
Cassette (Rear Cogs) SRAM PG-730, 7-speed, 11-32t
Chain KMC Z7 w/ reuseable Missing Link
Chainring(s) 42S x 32S x 22S replaceable outer
Crank SR SunTour, square taper spline
Pedals Composite cage and body, 9/16"
Gearing
Derailleur Front Shimano Altus, 34.9mm clamp
Derailleur Rear SRAM X-4, mid cage
Gears 21
Shifter(s) SRAM X3-R trigger
General
Grips Specialized Enduro, dual compound Kraton, no flange, 131mm
Handlebar Hi-Ten riserbar, 32mm rise, 640mm wide, 8 degree back sweep, 6 degree up sweep
Headset 1-1/8" threadless, loose ball
Saddle Specialized XC, Body Geometry, 143mm width, front and rear bumpers
Seat Post Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
Seat Release / Collar Alloy QR, nylon washer
Stem Forged alloy, 15 degree rise, 25.4mm clamp
Misc
Notes Chain stay protector, reflectors, clear coat, owners manual
Suspension
Fork Travel 80 mm
Forks SR Suntour SF8-XCT-V2, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, coil/mcu spring w/ preload adj., size-specific spring rates, spring assisted seals
Wheels
Hub Front Forged alloy, double sealed, ground race, steel QR, 32h
Hub Rear Forged alloy, double sealed, ground race, steel QR, cassette, 32h
Inner Tubes Schraeder valve
Rims Alex Z-1000, 26", alloy, single wall, 32h front and rear
Spokes 2mm (14g) stainless
Tire Front Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
Tire Rear Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
Wheel Size 26"
#6 mixitron
Postavljeno 17 July 2010 - 01:10 PM
Hmmmm... ovaj spisak opreme me koleba u preporuci. GT dolazi sa 3x8 brzina i nešto je jeftiniji, što ostavlja prostora za upgrade nekih lošijih delova u odnosu na Spec-a.
S druge strane, ova trostruki-trougao geometrija na GT-u je teška rava kad se kače torbice za ram, kad se bajk montira na nosač u gomili...
#7 r1m1
r1m1
  • 5 posts
Postavljeno 18 July 2010 - 09:31 AM
Tako da po tom pitanju, uzmem Specialized ?
Hvala !
#8 -mp-
-mp-
  • 76 posts
Postavljeno 18 July 2010 - 09:50 AM
Pošto već kažeš da si početnik: jesi li razmišljao o nekom drugom tipu bicikla osim o pravim MTB-ovima kao što su ova dva?
#9 r1m1
r1m1
  • 5 posts
Postavljeno 18 July 2010 - 02:39 PM
Kao naprimjer ?
#10 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 18 July 2010 - 03:12 PM
Meni su oba sasvim korektna za pocetnike.
#11 mixitron
Postavljeno 18 July 2010 - 06:48 PM
Kao naprimjer ?
Pa na primer, kupiš neki amaterski bicikl, recimo poniku :roll:
Mislio sam da kažem da je GT bolji po mogućnostima koje nudi za kasniju nadogradnju a Spec ima *malo* bolje neke delove.
Ako misliš da voziš do 1500 godišnje, uzmi onaj koji ti je lepši.
#12 -mp-
-mp-
  • 76 posts
Postavljeno 18 July 2010 - 07:49 PM
Kao naprimjer ?
Pa možda nešto više okrenuto drumu? Sada ima dosta toga između specijalki i MTB-a, i to po finim cenama.
Tj. da li je siguran da mu treba pravi MTB sa sve kramponkama? Nije spominjao gde i koliko (namerava da) vozi...
#13 Sirius9
  • 2510 posts
Postavljeno 18 July 2010 - 07:56 PM
još 1 glas za spec...
:D
#14 mixitron
Postavljeno 18 July 2010 - 11:18 PM
Pa za 15€ može da uzme par drumskih guma za MTB, mnogo li je?
Planinac možda nije najpraktičniji bicikl za sve uslove po odnosu energija/brzina, ali mu je sve kuća - i ravan drum i šumska stazica.
#15 Aleksej
Aleksej
  • 100 posts
  • LocationTetovo, Makedonija
Postavljeno 11 September 2010 - 09:15 PM
Zdravo svima !
Ja sam novi na forumu, a forum-odlican !
I ja se spremam za novi bicikl, a nadovezujem se na ovu temu jer su ova dva modela i moji favoriti.
Moja filozofija je sledeca:
Cena za ceo bicikl bi bila do max 500e, stim sto je meni najbitnije da ram bude sto bolji, a ostalo i onako moze se zameniti po potrebi.U siri izbor ulaze sledeci:
1.specialized hard rock disc 430e (A1 Premium Aluminum)
2.gt avalanche 3.0 410e (6061 aluminum with Hydro formed top and downtube)
3.merida matts 20 md 400e (matts pro d)
4.trek 4300 540e (Alpha Black Aluminum)
5.scot aspect 55 430e (Hydroformed Aluminijum 6061)
6.ktm Ultra One (Aluminium 6061)
7.polar mirage disc 272e (alumunijum 7005)
8.moongouse Tyax Comp 370e (al 6061)
9.giant YUKON DISC 2010 480e (AluxX aluminium)
ili mozda neki vas predlog, ali ovih brandova jer to moze da se nadje u MK.
Molim za komentare i savete i ponavljam- najvise me ram zanima.
Hvala.
#16 pavle93
pavle93
  • 598 posts
  • LocationNis
Postavljeno 11 September 2010 - 09:28 PM
Aleksej, dobrodosao na forum :D
Posto je Tetovo blizu Bitoli, u centru Bitole imas radnju ExtremeBike (u ulici Sirok Sokak, kod spomenika Aleksandru Makedonskom), tamo imaju razne GT-je, Specialized i ostale, pogledaj, cene se krecu od 15000 denara pa do 120000.
Puno srece u nalazenju!
2010: 4215 km
2011: 6021 km
#17 Allex
Allex
  • 1475 posts
Postavljeno 11 September 2010 - 09:31 PM
Kao prvo dobrodosao na forum =D> =D>
E sad..ja sam oduvek otkidao na GT Avanche,ali to sam ja.. :D
Sto se tice ostalih sve su to dobri ramovi,proizvodjaci su vrhunski,najbitnije je da ram aluminijumski ostalo zavisi od tebe ,tj da li ce ti geometrija tog proizvodjaca odgovarati...
Sto se mene tice ja bih odavde izbacio samo Polara i Meridu...
A sto se tice polovnih bajseva,da li si to gledao??? :?:
Za te pare mogao bi da nadjes pravu zver...
#18 arioth
arioth
  • 2939 posts
  • LocationMagnitogorsk
Postavljeno 11 September 2010 - 09:32 PM
Pa Tetovo i nije bas blizu Bitolja, ali nema veze. Skoplje je na 42km pa mozes da biras sta god hoces za bolje cene
#19 arioth
arioth
  • 2939 posts
Postavljeno 11 September 2010 - 09:33 PM
Na to se ne nadas ako zivis u MKD. Jednostavno nema takvog pijaca kod nas kako kod vas
#20 Allex
Allex
  • 1475 posts
Postavljeno 11 September 2010 - 09:42 PM
Bas steta...
mada mogao bi i kod nas da pogleda,nije daleko,komsije smo :wink:
Za dobru biciklu do 500 e mogao bi da se pomuci malo dalje da ode...
Ali naravno ako decko nadje u MKD sta mu odgovara,to je jos bolje.. :D
Posto je pomenuo da mu je bitan ram,mogao bi da vidi i RAM-ove bicikle,koliko sam citao ovde,njih imate u Skoplju??A i Arioth tvoje kritike za taj ram su jako dobre... :)
Samo ne znam u kom su cenovnom rangu?? :|
